yeah it winds up peak at 4200rpm
check out some std rb26 dyno plots in the forced induction section and see how yours compares
im not sure youd make that power if you did have a crack in the intercooler
id expect it to be fairly low power and boost peak around 6k instead of at 4
Yeah had a good look at the dyno thread, somethings up not sure what though but still making good power thinking of maybe getting a hard pipe kit or something might be a leak somewhere under the shield / shell of some of the piping
Did you get Chris to look at FMIC/Piping?
Check clamps which wouldn't be a bad idea, old clamps - let some air out making it bit lagger, absurd I know but.
Yeah he had a look but couldn't find the cause checked the usual stuff, he said it might be something that we cant see e.g high flowed so could just be wasting time / money.
It should fix itself up when I get some new turbs and intercooler kit i think
U say that like it was so long ago kid.
4 years
Billlllllly. Sec or prim!? If sec. Feel bad for ya.. Student teachers copped Alota shit from us lol.
Edited by Mohsen
4 years
well...its been 10 for me. and longer for most of the guys here.
kid.
I was at tafe only a year and a half ago :( pretty fun driving past all the mechanics in the skyline while they all got VT commos then I hop out with my laptop full nerd spec lolol :D
Shan - give me a BJ first
all good liked it :thumbsup:
MOARRRR INFO ABOUT EXEMPTION
no way I'll swap for a civic..
i'd say she can get the exemption because of her age, shes 26 years old and a p plater :blink:
I'm not going to question her about it incase she actually can't get one because then I would have talked myself out of a sale :P
It's all looking set, she's sorted out insurance. She's happy with my price and inspecting the car tomorrow with the intent of buying as she was looking to get a bank cheque organised. Yay!
Edited by llama_au
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
