dmax boot and roof spoiler yes plz
only if your going the full look like this guy, id say gtr front bar and spoiler + lows is better
probably just knocked the cable going from the PTU to the coilpacks a bit. engine moves when under load, just enough to cause a break in signal.
yeh took it out this morning up an down the street full acceleration no issues, apart from shittty neighbours id suspect
i need a service plus my front pipe put on and my new tie rod ends and some new suspension bushes also new engine gaskets installed. soo... who wants to do it :)
Front pipes is an easy job if you have ramps. Tie rods are easily replaced too but will require an alignment. Engine gasket is heaps of work. I'm lazy lol
my niggas
had someone call sayin they have an S1 GMG r33, LSD coileys has a dent in the back quarter (where a pod will be fitted)
dude says one of the lifters is noisy and its auto.... soooo how hard is a manual conversion and how costly would it be to fix the lifters
my niggas
goddamn you're a deadset dropkick. hasn't buying one shitty auto and dreaming of converting it to manual taught you anything.
take the money you'd spend on the 33, add 1k to it and then buy a manual instead. rather than buy an abused auto and spend 3k converting it to manual.
seriously, you're living proof that Darwinian theory doesn't apply to humans anymore.
Well the r32 is hard enough to get rid of. And I need a car ASAP
Their bog slow and I have an auto license so I dont mind if it's auto or manual.
Another offer was for an 06 bf falcoon wagon lol
I'd rather buy a bike what can 4-7k buy you for the car a kit and some rims? :domokun:
Maturity kickin' in yo - shouldn't do the gtr up >_<
Just a bit of a personal question - you guys/gals that are 25 ish renting or got a house? or still living at home? and to add those that do have a house what age were you when you moved in and was it with a gf / wife / a Mohsen?
I'm still living at home myself but thinking of just saving in the next few years for a deposit, have 25k of commonwealth bank shares atm so it would help with the initial saving
26, 27 this year. Live with my inlaws, have been for about 5 years although I've been with my partner for 10 years. We bought land last year and will likely start building this year.
Cool :thumbsup:
In other news, wanting to go to winton next month for sau championship - how hot can my engine oil get to safely? because I probably wont have oil cooler installed by then so was thinking of doing hard lap then 2 slow ones or something? or am I being to soft I do notice the gauge go up a fair bit during a hill run when i'm not even pushing the car that hard at all is 140 ish safe to be running on?
140 would be max. But u may find it a bit cooler on the track with 2 laps. We r talking about 5mins max on load. Not. 10-15 min moutain run.
No cooler is not ideal, but safely safely as she goes would be the plan. Catch tank for gtr is what u want tho, from what ive seen the stockers blow a bit (5-6 have done this, u end up with oil dripping from the pods)
My gtst never got over 100deg with the cooler.
Hamish that is hawt!!!
Also i run down a smurf, ran him through the blender and he is know lubing my gearbox :P
Skyline possibly gets inspected this Sunday when I get back from DECA. I say possibly. Hopes are not up too much given track record and I'm starting to sound like Mohsen. Please cross your fingers for me :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
