dmax boot and roof spoiler yes plz
only if your going the full look like this guy, id say gtr front bar and spoiler + lows is better
probably just knocked the cable going from the PTU to the coilpacks a bit. engine moves when under load, just enough to cause a break in signal.
yeh took it out this morning up an down the street full acceleration no issues, apart from shittty neighbours id suspect
i need a service plus my front pipe put on and my new tie rod ends and some new suspension bushes also new engine gaskets installed. soo... who wants to do it :)
Front pipes is an easy job if you have ramps. Tie rods are easily replaced too but will require an alignment. Engine gasket is heaps of work. I'm lazy lol
my niggas
had someone call sayin they have an S1 GMG r33, LSD coileys has a dent in the back quarter (where a pod will be fitted)
dude says one of the lifters is noisy and its auto.... soooo how hard is a manual conversion and how costly would it be to fix the lifters
my niggas
goddamn you're a deadset dropkick. hasn't buying one shitty auto and dreaming of converting it to manual taught you anything.
take the money you'd spend on the 33, add 1k to it and then buy a manual instead. rather than buy an abused auto and spend 3k converting it to manual.
seriously, you're living proof that Darwinian theory doesn't apply to humans anymore.
Well the r32 is hard enough to get rid of. And I need a car ASAP
Their bog slow and I have an auto license so I dont mind if it's auto or manual.
Another offer was for an 06 bf falcoon wagon lol
I'd rather buy a bike what can 4-7k buy you for the car a kit and some rims? :domokun:
Maturity kickin' in yo - shouldn't do the gtr up >_<
Just a bit of a personal question - you guys/gals that are 25 ish renting or got a house? or still living at home? and to add those that do have a house what age were you when you moved in and was it with a gf / wife / a Mohsen?
I'm still living at home myself but thinking of just saving in the next few years for a deposit, have 25k of commonwealth bank shares atm so it would help with the initial saving
26, 27 this year. Live with my inlaws, have been for about 5 years although I've been with my partner for 10 years. We bought land last year and will likely start building this year.
Cool :thumbsup:
In other news, wanting to go to winton next month for sau championship - how hot can my engine oil get to safely? because I probably wont have oil cooler installed by then so was thinking of doing hard lap then 2 slow ones or something? or am I being to soft I do notice the gauge go up a fair bit during a hill run when i'm not even pushing the car that hard at all is 140 ish safe to be running on?
140 would be max. But u may find it a bit cooler on the track with 2 laps. We r talking about 5mins max on load. Not. 10-15 min moutain run.
No cooler is not ideal, but safely safely as she goes would be the plan. Catch tank for gtr is what u want tho, from what ive seen the stockers blow a bit (5-6 have done this, u end up with oil dripping from the pods)
My gtst never got over 100deg with the cooler.
Hamish that is hawt!!!
Also i run down a smurf, ran him through the blender and he is know lubing my gearbox :P
Skyline possibly gets inspected this Sunday when I get back from DECA. I say possibly. Hopes are not up too much given track record and I'm starting to sound like Mohsen. Please cross your fingers for me :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
