Members only detailing day posted :D
http://www.skylinesa...-detailing-day/
Should be awesome.
Also Advanced day to come in future
Ah yes, Hamish mentioned this at the SAU General Meeting.
Sounds interesting.
A bus carrying only ugly people crashes into an oncoming truck, and everyone inside dies. They then get to meet their maker, and because of the grief they have experienced; He decides to grant them one wish each, before they enter Paradise.
They're all lined up, and God asks the first one what the wish is. "I want to be gorgeous," and so God snaps His fingers, and it is done.
The second one in line hears this and says "I want to be gorgeous too."
Another snap of His fingers and the wish is granted. This goes on for a while but when God is halfway down the line, the last guy in line starts laughing. When there are only ten people left, this guy is rolling on the floor, laughing. Finally, God reaches this guy and asks him what his wish will be.
The guy calms down and says: "Make 'em all ugly again."
It doesn't surprise me that most people think the age of consent is 18+, the laws are as vague as that friggen book^. It's like they purposely avoid saying that if you are 16 and over, you can have sex with anyone over 18 provided there is no duty of care or supervision between parties and it is consensual. Was that so hard? Instead they leave a myriad of clues towards it, stating what you can't do, instead of saying what you can.
From a book I got from year 11 VCE, "The essential guide into adulthood"
You have this at school?
I didn't get any of these when I was in school.
Get to travel to Cairns next week for business already woot already loving this job :thumbsup:
What do you do for living now?
I hope it pays enough for you to spend on the R.
The line has already been pointed out, and it's 16.
Not sure what gives you the right to call any of us "pedophiles" when we're not breaking any laws AND it's all 100% consensual?
Legality is one thing. By the eyes of the law your fine. To the eyes of everyone else you will look like a pedo. Not to mention most 16,17 year olds are head f**ked
bs man
clearly this is based on no hand no field work what so ever.
virginity confirmed.
Yes i was gonna day wtf is Mohsen commenting in this. He prob never seen a pussy that wasnt on his computer screen
guess they figured you werent gettin any :rofl2:
this.
dont give a fk if its legal a 20+ year old with anything under 18 is a pedo.
It is the Crimes Act after all.. not the Where You Can Put Your Dick Act
But luckily I speak fluent Legalese :D
bs man
Immaturity confirmed.
Wait, so when you were my age you were not hangin for anything that came your way?
That said there are exceptions (eg: boz spec) and remember I am 18 so the age gap isn't that different to me.
As for someone else here. Hypocrite!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
