You call it suffering, some of us call it earning.
I agree to an extent, if your parents want to take care of you and they can afford it then fair enough... but you've got to draw the line somewhere, i wouldn't call it 'suffering' to not have a Lambo at 22 years old lol
That wasn't what I meant. Just saying nothing wrong with giving your kid what they want if you can comfortably afford it. I wouldn't turn down the offer and I doubt any of you would ;)
no but there is also the flip side to the coin...
very often the kid who gets everything turns out to be a snotty arrogant shit with no concept of money. this is NOT what you want to give your child
FFS i tried to research oil catch cans... resulted in even more confusion.
Can someone please learn me on how to set them up, which one to buy etc. Would prefer the non vent to atmo type
Thanks
how crazy you want to go, i just set a very basic one up for less than $100.. Greddy style tins on ebay for $33 plus 15$ postage 1 metre of black oil hose from enzed $30 mount it away from your turbo cause you dont want it hot, I mounted it under the airbox and run the lines through the old intercooler hole. Pretty simple but effective enough.can post pics if u like. however if you are getting excessive blowby might want to consider a more elaborate setup
Thanks
Connect a justjap / autobarnz / ebay can between the cam breather and intake pipe.
I made the hoses long to reduce the speed of the air so it wasn't just going to suck oil vapor straight out of the pipe. As there are
no baffles in these cans.
guy at enzed didnt agree your long hose theory John, reckons it will travel at same speed regardless. I dunno im not convinced either way yet.
But apparently its good to have it somewhere cool as it helps it condensate, Meaning it will seperate from the air better
Really, so having the pipe work 10cm in, 10cm out. With for instance 100cubic mm of surface area for the oil to come in contact with. That is going to
perform the same duty as 45cm in and 45 cm out with 450cubic mm of surface area for the oil to come in contact with? Surly the more you can
break down the vapor the better?
but yeh maybe he is right, the air may not 'slow' down as such.
after 30 odd track days my can only has residue inside it and the intake pipe is clean.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
