imo, f**k clubs. maybe thats because we always get thrown out....
seriously though, bottle of scotch is like 50 bux from a bottle shop, they charge 9 bux for a squirt of it.
if your getting smashed on a budget drink at home
You always get kicked out of clubs.
What club do you goto?
They obviously don't like ya's :laugh:
yeh you lads are out of touch when i use to go out 6-7 years ago was minimum 200-250 per person so the rate of inflation/hectic hotspot tax id imagine id be dropping at least $350 + on a propper night out.
but i gotta gf and thus no life so its not an issue for me :rofl2:
Start dragging that ball and chain.
Haha nah I work so it's not like I can get wasted an have a hangover
Hah!
True that man.
It's my hot head friends that can't let things go. I'm usually the one breaking shit up.
Crazy kents!
sup wasteland can i get a TL;DR on the last few pages, ceebs reading
Drinking alcohol.
Getting wasted.
Spending $200 - $300 a night on going out clubbing / drinks.
Moh's friends starting fights and getting kicked out
Alex is pussy whipped :laugh:
But he loves the pussy anyway :thumbsup:
-Someone bought a Mazda 6 MPS
-CX7s aren't fantastic
-Talk of the usual meat based meals / every c**t's parma is the biggest/best in town
-Alvin's car is going to be the fastest panelbeater job in history
-Some people are paying too much for their drinks
-Some people are drinking too much for their pays
-Mohsen and friend(s) are responsible for the inclination of street violence in Melbourne
-Alex has no life
Lol I wish I was Alvin on Saturday. Blew 300 bux on drinks. Could still walk. Legendary
rather be a lightweight, i love it can get pissed on fark all $$$
although after my trip and especially vietnam and paying 60cents max for a can of beer ive been able to handle more booze
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
