its ok i found out the info
theres only 1 purple for GTR 33
some just look better than others
there's only one MP1 which all purple R33's were (GTR and limited numbers of S3 GTSt's), and MP1 doesn't have pearlescent mica in it like that car.
vetike, bo-ge-la-ma
can we go home?
some sort of retarded pick up line?
you wanna say "sin-na vetike, bo-ge-la-ma" which is "can we go to my mistresses' house?"
buying a GTR already modded is a better way to go.. but then the car isnt 'yours' which is why i got mine stock for 22.5 but yeah would of spent close to 30 all up on silly stuff now anyways but its all a learning curve and fun.
can we go home?
oh, so that's the go home one,
i had a soldier, back in the army, he was singaporean tamil, he thought me 2 phrases, one of which was that, because i was in charge of him, he always wanted to go home early.
i can't remember the other one.
That GTR looks awesome and fair mint. Lovely colour. If you're going to modify one anyway, you'd offer him 27k and be in a better position than most GTS-Ts that have racked up that cost in mods alone.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
