its ok i found out the info
theres only 1 purple for GTR 33
some just look better than others
there's only one MP1 which all purple R33's were (GTR and limited numbers of S3 GTSt's), and MP1 doesn't have pearlescent mica in it like that car.
vetike, bo-ge-la-ma
can we go home?
some sort of retarded pick up line?
you wanna say "sin-na vetike, bo-ge-la-ma" which is "can we go to my mistresses' house?"
buying a GTR already modded is a better way to go.. but then the car isnt 'yours' which is why i got mine stock for 22.5 but yeah would of spent close to 30 all up on silly stuff now anyways but its all a learning curve and fun.
can we go home?
oh, so that's the go home one,
i had a soldier, back in the army, he was singaporean tamil, he thought me 2 phrases, one of which was that, because i was in charge of him, he always wanted to go home early.
i can't remember the other one.
That GTR looks awesome and fair mint. Lovely colour. If you're going to modify one anyway, you'd offer him 27k and be in a better position than most GTS-Ts that have racked up that cost in mods alone.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
