Lmao at the jokes
Lmao at jizzy correcting the teacher
Lmao at Billy being a teacher
Lmao at me lmaoing at Billy for teaching while Billy is lmaoing at me because all he gets to do is sit there and talk to a bunch of retards while getting paid.
I'm fair bored. Hungry, been a shitty week
permawinter!
my laundry is piling up because i have no car.
they said to call back and check at 3pm, because the replacement exhaust aint here yet.
is the exhaust all your waiting on now man?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
