lol wtf, what you made think of that?
well theres not much else to choose from with my price range plus i would still have a good amount of money left over for the future and i have always liked these cars, they look great and have got plenty of power.
has anyone on here driven one or have any opinions on these?
whats your budget and car requirements?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
