What the f**k is wrong with half the people in here!!
I missed out on a lot tonight and don't know where to begin.
1. A man should get a haircut about once a month. I mean really, who the f**k straightens their hair, your not Justin Beaver or David Beckham circa 1999. Grow up and get a haircut.
2. I've been going to the gym for many years, off at the moment, dislocated shoulder... I've lost heaps of size. I don't tell people I go gym, I don't make a big fuss of it, nor do I or have I had any supplements... I do it for myself because I wanted to be stronger for the sports I play.
3. People posting pics of themselves topless are douchebags... Unless your a chick. Honestly, no excuses unless it's holiday beach pictures or something.
Seems to be more muzzas on here than I thought.
Reeeeeally? Interesting, did you go to the same place and did they use the same product? I know that there are a few out there. My girlfriend who recommended it to me has seriously curly hair naturally and she's had hers done perfectly for years. We both went to a place call SUI in the city on Bourke Street :)
Same place, I think it was the same product but a different person doing it. First time around - awesome, however still needed to use a hair straightner but not as much. Second time around hair went dry, frizzy, all broken on the top, permanent kink in it etc. I think it's kinda put me off doing it again. I have to straighten my hair every day but only spend between 5-20 minutes because I seriously cannot be bothered with any longer and I don't care enough.
Ah that sucks :( I was paranoid about mine (would look stupid with short hair) but thought my girlfriends was a good example. The ends are a bit split from having foils done years ago which I know can make a difference but the rest is fine. I guess only time will tell :)
Quoted for truth.
I was learning to drive manual in a car with a short shifter and a leg breaking clutch...and 255rwkw lol
Was strange then getting into a car with a normal shifter and a nice easy clutch. Actually I found it more difficult.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
