haven't had a look yet but my ex used to do them at home so can't be too hard right?
hah yeh try to get ANYTHING done right before easter long weekend.. not happening.. seems easier to do it myself as usual, besides then when something is fckd I know what it is :) I don't have to go back in there 500 times to get them to fix their crap...
i have never seen a car u can change a pad without removing the caliper. Do they exist?
Look its pretty easy
remove wheel
undo 2 bolts that hold caliper on and remove
unclip and remove pads
push pistons back in, helps if you remove the reservoir cap
put in new pads and refit calipers
also, if I don't take it to a good friend.. they will *guaranteed* tell me I need new rotors, whether I do or not, AND I need to mount a speedboat onto my radiator fan because otherwise a wheel bearing will go flying out of the passenger footwell and take out the fuel pump on it's way..
If I even try to argue that logic a little bit then they become defensive real quick.. randoms are unable to do exactly what they're asked and only that.. guaranteed they will find an african elephant in an intake pipe that needs a new turbo to fix, because I'm a woman, what would I know??
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
