Is she the hottest? What about Ferah? or that asian chick (can't remember her name)?
I don't exactly pounce on every girl that posts on a forum :P No need when I've got at least 3 girls coming over right now :)
lol some good calls being made right now.
And then you got the whole cut vs uncut debate
Don't even start me on that shit, seen enough /b/ debate threads to last a lifetime.
The hottest chick on SAU posts in the wasteland and you're all talking about cocks?
Smooth move dezzeray, you in yet?
P.S. rule 16
Anyone get pinged on the movie cruise?
Nah, not that I'm aware of. Everyone was well behaved and no sign of any cops near the drive in. Everything went better than expected!
what asian chick?
i beleive Dezz is on the money though ;)
like lol
Well Sandra!
Been a while and you posted for once :laugh:
Karla..?
Did I stutter?
:laugh:
