moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem moh jem moe jem mo jem
ya'll get te point
I'm terrified of heights. Kris and his brother made me go :P
I instantly regretted giving in :P
i'm terrified of heights too..
what i do is man up and go for it, once they lock you in, there's nothing more you can do except scream!
Was at Surfers Paradise for Easter. Good Fun
0 - 100km/h in 2 seconds (Superman rollercoaster)
No car can achieve that feeling :(
Brilliant ride. I find that lethal weapon is the most 'unnerving' ride out of all the parks. Hanging buy your ass as you climb up to the first drop.
Haven't been on superman but apart from that pretty much every ride across all of those parks are kiddie rides compared to the stuff at six flags in Cali.
I've never been a rollercoaster person, and went to six flags the day after a big night of drinking, but I went on everything there at least twice. They have the batman which is the same as the lethal weapon, and it's pretty much the tamest roller coaster there.
YouTube Goliath and tatsu, that's where it's at.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
