Who stays till morning more like don't wake her when you leave
post coital deuce is important. leave toilet seat down for when she wakes up the next morning.
also, unless you sleep with beasts, stayin in bed for breakfast is your right as a man. fuck sneaking out after the deed. easy way to miss out on wake up sex and a meal.
Lol it's turbooo. What did your flutes cost ya if you don't mind me asking
buy ceffy. turbo and exempt.
What time were ya there? Not that I'd recognise you but I spent a good deal of time there lastnight. Crown se urity are way too efficient, you see about 10 seconds of a punch on and the swarm is already there.
Anyone hitting up Geebung today/tonight?
One of my mates got smacked around by crown security last night. Reckons there was about four of five security guards pinning him down after a bit of a confrontation. They sound like a bunch of heros those security dudes imo.
My ex best mate is/was security there. Put some guy in hospital once. Crown is the last place u want to be a f**k head and get in a fight.... Endless security
On another note, someone call 000 and get some cops to etihad stadium ASAP. There's a rape in progress
Around the area from 9pm to 6am lol in the Casino till about 12 ish
And yeah, the security are massive heroes. The bouncer to let us up stairs to the Fusion club and shit was really anal about shoes and stuff.. a lot of people got told to get the f**k out of the line by this douchebag and they wern't happy at all which is understandable.. yelling at him to step outside.. tuff guy etc etc.. I was just /facepalming. These guys were dressed completely fine as well.
Also - stripper sliding down the whole stage bare ass on soapy water was pretty cool, chick had some skillz & tricks. Best one by far.
Yeah they work on numbers. I had a mate who worked for security there, he was 60kg lol didn't matter though, you get 10 x 60kg guys coming after you, you're leaving the premises. What I don't understand is why people try to fight against security - you're not going to win!
well, they just throw you out for being unruly right?
do you get banned or something as well?
You get thrown out and that's it. If you hurt one of them or you're stupid drunk, they throw you out the "back" door which backs onto the Yarra and that comes with an added ass kicking.
If I got banned from Crown I'd be devo.
Where else can I play casino war?
I hope you're not serious. That game is the most mindless shit since Crown's take on two up. When I walk past war I can practically see trollface.jpg on the dealer's face. Play three card poker or blackjack mayne.
Lol what?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
