dunno where that is lol
this guy trains at fenix point cook his afkn beast always has green wrfl shorts on tatts on shoulder/arm fit as all hell guys an animal wouldnt wana play against him :wacko:
Green shorts, probably Spotswood...Yellow lettering?
Probably play him in 3 weeks..lol
Dragged some VT clubby after lunch today - was lols. (to the speed limit anyway)
Lol asif bother with that.
Had some dumb shit in a black r33 go at me. Lets just say he was waaaaay back. Comes and asks me my power at the next lights and claimed he has 280rwkw. I just looked at him and went. "no mate you don't. This is 280rwkw." his passenger was pissing himself laughing.
and LOL @ 3/4 filling a tank for economy... All of what, 5-8Kgs of weight? hahaha... i cannot fathom...
You'd get better gains running 4psi more in the tyres.
And filing up 3 times a week = you be paying more @ worse times = less economical
That blokes a f**kn machine!
Try driving a 4cyl car with barely much more than 200kw, you feel the difference, trust me!!
Like if I have a 100kg friend in the car the bloody thing just doesn't move. Not like my ZX when I could have 4 passengers and still get pushed back in the seat a bit.
actually ther arnt all bad
evo goes all with car weight of 1400kg and 205kw
even with passengers
I doubt a little tuna can car has as big of a tank, i bet its single figures!
Im waiting for the next idea of leaving the spare tyre/jack out for weight reduction.
Or like that other idiot in the Skyline Discussion who removed the A/C to increase fuel economy/lighten the car LOL...
I said 3/4 is the max I've ever put in. It normally sits around 1/4. I put in $30 when it gets close to empty.
Also if it's expensive then I'll only put in about $10 and wait for the price to go down. I only put in $30 if it's cheap.
Weird system but it works for me.
EDIT:
Lol @ tyre/spare jack..... I removed my spare tyre and tool kit the day I got the car :P
Edited by jezza boii
i bet your fuel system likes all the shit floating around from 1/4 tank too
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
