I've made really lame ones and had heaps of likes.
Exhibit A: http://www.facebook.com/pages/Dear-Summer-Youre-doing-it-wrong-Sincerely-Melbourne/174293695938785?ref=ts
Edited by jezza boii
I had a group that had like 900 people. Keep in mind that I made 898 accounts and joined the group.
It was the "join this group if you think Mohsen is gay" group, wasn't it?
Reasonable. But most people I know have their pretty stock r34 gtt coupes insured for 20k.
Even my sedan was insured for $20K.
But that's the beauty of having full comp and not relying on someone else's insurance to cover damage to your car.
Edited by llama_au
Technically it's more economical to fill up in small amounts though. I do about 3 lots of $30 top-ups a week. Probably does shit all but I'll do anything to make my car faster :P
I drive every day and my car costs me about $15 per week on 98octane. Mad?
Edited by llama_au
L4D 2 Lags like shit, how do i reduce latency? I've tried portforwarding and its brought down my lag but its still 300+
wonder what the housemates are downloading...
Depends on the host also. Could be some guy from the other side of the world. Or could be your housemates down / uploading porn.
OR your connection could just be shit.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
