Lol yeah because I chose to stick around with dad and learn shit than go do shit with friends. Go from school to work then home. Also. I don't think wearing clean gray tradie shorts and a collared t shirt with the actual company logo stamped on the front of it. As well as hair that's done nice and neat.
As I said. I don't go to sus out shops and stand around and talk shit. I go in, pull out the equipment, measure up. Note what's needed to remove etc and then report back to dad.
Maybe in a few years I can rock up and actually look like a manager etc and have workers do what we have to do now.
As for the age and experience thing. I cop that alll the time. Get people coming in asking for Mohsen. Then they proceed to go on about how young I look lol
Yeah I'm the youngest bloke at my work - When I have to work in stores (computer upgrades / new store / what ever) just got to walk in LIKE A BOSS! I actually use to wear nice pants and shirt when I started but it makes it a bit hard lifting / screwing around with computer boxes and shit, so these days just been wearing jeans and a t-shirt.. no complaints yet. (I work for the body shop) - I.T though so..
no homo.
I don't know what it is exactly that Mohsen does for work, but sometimes looking too white collar can offer up a negative image for your client. Really depends on what industry you are working in.
Take for example, when I used to do sales repping for my family's oil distribution company. Visiting automotive workshops, I found the owners treated you more like one of their own if I was wearing a logo'd up polo and a pair of steel caps. There's also much more sincerity to your "how's business going lately?" than if you are wearing a shitty tie and target spec shirt, looking like you've never picked up a spanner in your life. I've seen a lot of wanky looking reps in my time...so many of them fail to break the barrier between supplier and client because they can't meet them on the same level. Which is a shame, because it does help with customer loyalty.
Another point is that, if you already have the client on board, they probably won't give a shit what you are wearing from then on out. First impression is the most important one. After that, focus will be on the job being done properly and how you can save them money.
this
such complicated issues tackled in here
reminds me of pillowtalk on the austereo network
or the "net at night"
No idea what any of that is!
Apparently my brother wants to buy my GTR and sell his GTST after going for a spin the other night hah
Now I can get a new Ford GS ? do want :D
By 'proper' pants/shorts I meant hard yakka pants/sorts etc....So you actually look like a tradesman there to do a job, not someone walking in off the street for minimum chips and a chiko roll.
Apparently it's not on and you should wear dress pants and a button up shirt no matter what...
when clients come over (after hours) to see my old man about quotes/plans etc he's in trackies. but when I/he go to see clients at job sites during work hours ofcourse you'd be wearing appropriate clothing although i've met up with clients a few times at sites in trackies but that was after work and being told by my old man to go coz he cant make it. if you're a tradie they don't give a f**k what you're wearing, your company's reputation is what counts.
just coz salesmen sleep in suits dont mean we have to.
Psst...dezzy...Pat said to buy a suit / some $10 slacks from Target (pronounced Tarjay) and Alex basically +1'd his post.
Wasteland detective out.
If that's the case then f**k that, tradie world is completely different. You don't rock up in a suit if you're a tradie, and if you do, you're a fuck head.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
