Ye i know what ya mean man.
lol yes this is true, i much prefer calling people... Thank christ i got on a Telstra staff plan a while back, dropped my bill by 2/3's overnight with a decent call rate/included cap/data.
Deleted my facebook, but a guy that played footy at my club last year (deliberately not using the word 'mate') has something like 1200+ friends
"I have over 1200 friends on Facebook/MySpace!"
"Oh really? How do you spend your Friday nights?"
"At home on my computer."
IT Operations. Im sorta T2/T3 support in a way, along with project implementation, incident management, SME for a lot of systems...
I basically do nothing thats in my job description, and everything that isn't.
sounds like what i did in the army.
Jett Black was win on Sat night...I shoulda messaged ya. Tried to get into Trak wearing T shirts BIG fail...did not know the dress code was super tight there.
The line at that place is ridiculous...you get there at 9pm, it stretches out teh shopping centre, onto Toorak Rd and half way up to the Grange Rd intersection.
Would a C34 Stag or an R33 sedan(Turbos obviously) fit the rules for a P-plate exemption?
No.
Are you sure? Cus going off these figures..
Stag
Curb vehicle weight: 1,620 kg (3,571 lb)
RB25DET - twin-cam TURBO (T3 Turbo) (245 to 250 hp and 319 N·m) 180KW
KW/T = 111
R33 4 door
Weight 1390kg
KW/T = 129
The Stag easily makes it through and the R33 just doesn't but wouldn't a 4 door be heavier? This is all provided these figures are correct of course.
Shame man. I couldn't even get to chapel. I was stranded in Brighton of all places. We should have another outing soon!
Stag
KW/T = 111
R33 4 door
Weight 1390kg
KW/T = 129
Why are you using a power to weight rule? P platers aren't allowed to drive forced induction vehicles regardless of power to weight. As far as exemptions go, I doubt you'll get any turbocharged, petrol engined vehicle past an exemption that isn't a slow farm or towing vehicle. They're very aware of people trying to use loopholes to drive fast cars, as Mohsen found out with his Skyline.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
