What do you mean starting to, it was always populated by dicks. The only time I remember it not being that way was when it first came about and hardly anyone used it, which defeated the point of having one in the first place.
They're all the friggen same anyway. People were delusional to think Facebook was going to be any different. Facebook = MySpace without the glitter.
Have you noticed the revert to MySpace though? There's actually a lot of celebrities, bands and clubs using MySpace pages now because it's no longer the "teeny bopper" site...Facebook is LOL.
Yeah it's all fucking shit.
I just load up Myspace Band pages to have a listen to their recorded tracks as they have a music player on load up.
Best way to preview their tracks.
Flip it hmm....
I like...
Off to do some maths, offset maths is the best form of maths.
Yeah man :)
Kids...
Back in my day we used a 9 pin serial port for some 1 on 1 C&C: Red Alert.
And if we weren't in the same room...it was 14.4k baby. We had BAUD rates too bitches.
cheeeeeah..... dont forget duke 3d over 28.8
What'd you hit it on?
I wish I had a cool story about drifting or something, but honestly... I hit a gutter in a beach carpark. Windows were fogged up so I couldn't see properly as I was leaving. Misjudged the exit and crunch.. Left side is caved in.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
