i originally took em out for moar lows why do you wanna put em in?
just get a 2nd hand set of coilovers or something..
helper springs compress your coilover springs so they dont fly around when you lift a wheel off the ground haha. People put them in so they can go more low without springs popping out of the seats!
I need to put some in, cause any lower and will pop out.
Paid a pretty penny for my new Bilstein shocks, which are far better than any chinese coilovers. Would be silly to bin them for more lows. Need to just spend more money to convert them to coilovers ~_~
East Bear
A trader used to sell em on here, but only had the beige/tan color which I wasn't a fan of, black was pretty rare...think they were something like $800 a piece back in the day + rails...I had Bride rails on em which aren't cheap either
Thought you'd be keen as mustard for footy training if you're so into running..
It's more the session times I can't deal with, rather than cbfs about training. Work sometimes holds me back late and Tues + Thurs are gym nights for me. Thirds is more about punch ons than footy though!
lol they pop out but they'll go back in place during/after compression. they were a bit noisy after i took em out but it dropped the height another inch or so.
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
