The R32 may LOOK better to some, as this is very subjective but no denying the R33 is the better car. And the 32 Interior is aids duno anyone who prefers it over R33 interior.
Excited to get my car back tonight after tune (status).. base dyno run was 238rwkw so only 5 off the racepace dyno so pretty much spot on when you take into account temp / baro preasure etc. I'll be happy to see anything over 260rwkw anything over would be a bonus for me, hopefully a lot more power early in the rev range as well.
How much for an extra 120K/w at the wheels in a GTR that has the following already
Power FC (180kw)
Nismo CAT
Well, I have a exhaust, adjustable cam gears, and modded standard boost solenoid to run 14PSI - 233rwkw or 238rwkw depending on dyno, and now adding a power FC I'll let you know tonight.
If you want 300rwkw usually people go 2860s -9s and you will probably need new injectors / fuel pump to be safe. So in my opinion if your going to do turbos.. go big so your not disapointed with a little power gain for $$$$ (no point spending 5k+ for what ~40 kw)
My 2c.
This is true. And r33s have aircon that works
Guest
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
