how do they go for comfort kris?
drove a evo 7 with bc a few weeks ago
damper was set down and fark me it was soft, like driving a normal car (especially compared to the stiff standard shocks of my car)
very nice ride though and can get them really stiff if you want
sweet! thanks very much guys!
i tried the method that leigh suggested and worked a treat - took a few little nicks out of the plastic and you can see how they are a lighter more grey colour than the black rubber/plastic
but still looks much nicer without the weathersheild!
so ill try one of those tomorrow - all avaliable from autobarn im guessing?
yeah autobarn.
You apply the liquid onto the rubber. Let it rest for a minute or so. Then buff it into the rubber. Crucial to let it rest for a minute or so, get best results that way. It does create streaks on windows/paint work. Can be removed wth Mothers Showtime
Non-original electronic chips or computers, whether
fitted as a direct replacement or in a ‘piggy-back’
configuration, are not permitted to be used in an
engine management system unless it can be
demonstrated that their installation and use allows
the vehicle to meet the appropriate ADR. They must
also be sealed or otherwise constructed so as not to
be reprogrammable.
So when going to an EPA inspection, arent you demonstrating that it meets/exceeds emission requirements and achieving ADR? It doesnt say that it must be ADR certified, just that it can meet it? Having Nistune would mean it is sealed and cant be reprogrammed without a license. Sounds plausable?
Also scanning over the EPA doc;
http://epanote2.epa.vic.gov.au/EPA/Publica...6;FILE/1031.pdf
Only mention of aftermarket turbo is below:
Note: aftermarket turbocharging kits that
include intercoolers that have been type
tested (ADR certified) for the model vehicle
are permitted. Documentary proof must be
retained to substantiate this.
What if it isnt a turbocharge kit incl intercooler? Being a 20yr old car, obviously brand new factory replacements can be argued as not available and hence an aftermarket replacement has to be fitted?
Also:
Alternative, replacement or aftermarket EFI systems
are not permitted unless ADR certified for that
particular vehicle make and model.
Extra or larger fuel injectors are not permitted.
This i believe is referring to fitting an aftermarket EFI system onto a carby engine.
There is no mention of aftermarket injectors not allowed only mention of larger/extra injectors.
So this means that bosch/denso equivelent injectors can be fitted so long as they arent larger. How can EPA check the size of the injectors anyways?
hmmmmmmmmmm
Any modification is permitted provided that it can be
shown, by way of test1 or engineering reason, to
show that the modification would not be expected to
cause an increase in emissions beyond a similar,
unmodified vehicle.
1 Test procedures used for demonstrating compliance
must be to the ADR applicable to the vehicle model. A
simple exhaust emission test at idle, steady speeds or
using an IM240 procedure is not acceptable.
hmm bummer
hey leigh, ive got a question for you mate. with your new coilovers how do you go with with adjusting the stiffness of it. is it done from the top of the coilover? and if so does it get annoying having to remove the back seats to adjust it? thats the only thing thats going to piss me off with mine i think.
^^ thats what i ordered. which model u get?
the BR series (gold) pretty much from my research in general just made from better products then the other slightly cheaper one I think.
I got suspension place to set up for street / track every 3 months and they did a good job i think, its really nice to drive now as a daily I do about 70km so suspension stiffness on my old Teins was a real back breaker, now it feels so much better I cant describe it you don't feel every little paint strip on the roads lol and yet when you turn sharp into or hard into something it still responsive and seems to handle itself.
Yo yo, I havn't adjusted it at all cost me like 300 all up with a wheel alignment and height adjustment to lowest legal, they setup the stiffness on what you say I told them I will be using it mainly for street and a bit of track work so they did so quite well I think (traction tyres in rowville) so couldn't answer your question apart from recommending to get someone else to do it, because they gave me a sheet with camber % and all these different readings which I had NFI about, and even if I did how the hell would one get into that much detail in there own garage with a jack.
Guest
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
