many times.... not a huge fan... they is ok...
dont let truffle oil put you off as they are much nicer than that IRL
when i left a job once where the boss was a complete tosser I ordered a kilo of white truffles on my last day
  • Like 1
wow you made a huge fuckoff tl;dr post to say exactly what I said in 10 words 15 mins earlier. gratz.
haha :thumbsup:
Lol at heel toeing for daily driving. Hardcore
lol why is everyone making heel-toeing sounding like its some hardcore shit like left food braking?? You slowing down for a corner/traffic light and whilst breaking you rev match for the right gear. Why would I ride the gears like a noob who loves teh chapel street?
your tyres will run out before the calipers do
ie upgrading to 6 pot on the front is great, but if your running normal tyres, you probably dont gain much except resistance to heat in the calipers as they are bigger
youd probably get more stopping power with better tyres
but people upgrade to bigger calipers for braging rights
plus it looks good
and i agree, it does look good
haha true that. Although the kit i linked is cheaper than the price of r33 gtr brembos the jokers are asking for.
Heel toeing is used in racing so they don't take their foot off the brake approaching a corner. There is absolutely no need for it on the street
nah bro, manufacturers of road cars put syncros into gearboxes just so that it looks good on the brochure, it's up to us emo 32 race car drivers to rev match the gears on the streets. I mean, what would they know, it's not like they spent millions developing a system so that you don't have to do extra work and look like some track day hero.
I'm sure Hamilton heel-toes his AMG too when he's drivin around London.
Guest
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
