need an answer to this quick:
Took my car to Beaurepairs to get my front wheels balanced! they finished and when I went out the guy tells me that one of my $250 kics nuts has been threaded and same as the stud on the spacer. Is there anything I can do? He told me they were hard to get off so he had to get them off by hand and it was f**ked already....
do NOT accept this.
look for signs of scratching on the nuts and see if they used the gun and then call head office and complain
tell them you EXPLICITLY directed them not to use a rattle the gun and they did due to nothing but laziness.
you want a new set of kics nuts or the $350 (retail) to replace them. also a new stud or spacershould be paid for
just go HARD
annoying knocking noise coming from one of the rear coilovers what does that mean? no leaks as far as i can see...
chek your bushes? Mine made knocking noises from the front due to worn rosejointed bushes
Give the tops and crack with a spanner.
Do you have a rear strut bar? That could have come loose.
Wheel nuts..
hmmmz
Wheel nuts..
you mean tighten the tops? they are..
no rear strut bar
wheel nuts are fine
old coilovers were a bit noisy but that was coz i had removed the helper springs and compressed the springs. these HKS ones are louder
Guest
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
