Shit is really off the chain.. I've got 1 semester left, time to make the most of it :devil:
There's a mint bitch in the full time class, damnnnnnnnn
No. There are no girls in engineering. It's like the internet.
Well cam gears will go in at the same time of the service (decided to sell my HKS cam gears to go tomei which was strongly recommended by Trent as well due to having 5 bolts rather then 3, dont want that shit coming lose ever), but will aid in the future when I get turbos / afms / injectors etc done.
Fuel filter wasn't included with the kit I got, so just added that on top (was through Kudos - Andrew is great to deal with as well) and couldn't be bothered shopping around for other air filter options Kudos only had HKS filter so just got that will be better then the current dirty as aids one in there.
So obviously I'll just be doing coilpacks, filters myself but timing belt is a bit advanced so going to a shop for that, any recommendations?
Cool!
I am sure Trent can do a timing belt for you...
No shit rashed.
Z
it's better this way.
after she knocks you back you won't have to feel akward having her in your class
Are Apexi pod filters any good? I acquired one for free :) Might put it in coz I've got some shitty "Monza" one in my car and its clogged up with all kinds of shit.
One of the best!
And you get the 'Dose' :laugh:
those monza ones are horrible
i tried one when i first got my car
and it dampened the throttle response
no idea how, but it was ordinary with the monza one
the apexi one is probably like the K&N ones
both would be good
interview done
went pretty well
will hopefully hear from them next week
lmao
really? so it was really a dood in a dress?
mannn that dood had nice legs
usually, after a knock back they want to leave.....
you know why?
Yeah will ask him about it, although I think he might send some of his customers off to GT hyper (for engine work)
Ah yeah I have been down to GT Hyper, I know a guy on AE86DC who works there.
K&N is oiled...not good for the AFM
That is the big misconception.
K&N filters are dry.
As the instructions in the K&N Cleaner Kit will tell you to apply the oil and only a thin layer... But you don't have to.
You can keep your air filter dry.
Guest
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
