This is interesting. I have no powerduct, but I did run for a few months with the little panel on the airbox removed. Not sure how much difference the powerduct would make vs not having anything there. The airbox sits so close to the front that I figured the only difference would be that it might suck in hot air when I wasn't moving, but in theory that should be better for fuel economy, not worse.
Recently I put the little plastic panel back on and realised the difference it made. With the panel back on again, I now have much better low-end response, smoother power delivery and the car feels noticeably faster. Fuel economy also seems to have improved a little, but not by enough to make any great claims about it. The main difference was in the ability to build boost at low revs...it seems having the airbox closed is good for building boost pressure early.
Top end performance was definitely improved with the panel removed, so I may have had a heavier right foot more often...
hmm... I put a Powerduct on last weekend and noticed an improvement in responsiveness almost straight away (my CAI has been disconnected until I make a new one that fits with the front bar). The difference was like trying to suck air in with your hand over your mouth (closed airbox and only stock funnel) as opposed to just breathing normally (with Powerduct).
Didn't really notice any additional sound although it may be a bit difficult to hear over my turbo and exhaust :banana:
The engine does seem to have a bit more of a sense of urgency about it with the duct on.
To each their own I guess, but the thinking that turbo cars need as much air to the intake as possible would make you think that the Powerduct would be more a positive than a negative for our cars, no?
I don't see either how by limiting air intake it could make the turbo spool any earlier.
It is hard to imaging how it could help low down power but perhaps it is like the opposite of a restrictive exhaust on a NA car where that helps torque.
From memory it is just a small difference anyway but I kept mine off as I liked the feeling it made to the power delivery at the top end.
Cheers
Andy
I dont understand why mine felt faster when I put the little panel back on. I cant explain it. But it definitely does seem faster or at least more responsive off the line now. It doesn't make sense...
There must be a reason why Nissan included the powerduct with all n/a versions of these engines and not with the turbo version.
emissions
  • 1 year later...
going to reactivate this thread.. hoping someone has worked out something to fix the fuel gauge.. mine is shocking can jump a quarter of a tank between starts.. i am on gas though like to keep at least a 1/3 in the tank.. though every few days it says i am near empty..
anyone got a fix?
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
