  • Replies 149
Nice work Russell & Ryan!
Hoped I would do better than 20th but that's a big improvement over 26th last time. I need to work on my wangs :(
List of excuses:
-Tyres scrubbing guards on every turn :(
-Fat passenger :banana:
-I'm a pussy with my daily driver :P
Damn, I thought I'd do a lot better than that. Those WD (and spinning out) really kill you!
Goes to show thought that you can do quite well without a huge amount of power. I managed better than decent times here and there, just lack the conistency! Guess that comes with driving skill and experience.
You're right about being more aggressive though, on my last mini wang run I went all out and managed a good time, and I know I wasn't at the car limits - just mine. :banana:
Yep, unless you got issues with your car it's almost all driver for these events. Agree totally, it's cool that with these results you can see where you did really well and know that if you were consistent in doing that everytime then you'd do much better overall.
595s are shit.
Go Hankook S1 EVOs or Conti SportContactIIs or the Kumhos Russell runs. 245s are plenty too.
RE001's are in the same area and price range as well for another option.
When i picked mine up they were the same price as the EVO's actually.
I think that's changed now though
Thanks but if "NA challenge" means normally aspirated the Lancer doesnt fit that bill.
it's basically an rb18det but is in the 2WD class for sure specifically FWD :thumbsup: understeer come on down.
go Russman! and also well done to the Clive in the Lancer for taking out the highly contested "NA challenge"..
How the hell did you fit a 6 cylinder in there?
ROFL, maybe I should have said rb1.8det, 6 cyl I wish
Hmmm thinks 6 cyl hmmm
I wonder (thinks some more)
hey Juliette I got this idea about how to promote the FWD chances at the next DECA
I thinking 6cyl twin turbo, whatcha think?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
