AMS Smash The 9 Second Barrier at TX2K10
March 21st, 2010 Goto comments Leave a comment
After beating out all the other competitors in the dyno competition, AMS have driven this SR850 tuned R35 GT-R to a worlds first 9 second ET at Lonestar Motorsports Park on their first run of the day!
They went on to run a string of 9 second passes with the best ET being 9.89 @ 145 even after hitting the rev limiter in second. The best mph of the day was 146.96 mph which you can see in the timeslip in the gallery below.
To get there, the car runs an AMS SR850 upgrade package which includes:
AMS upgraded bolt on turbo’s
Upgraded actuators
AMS 90mm downpipes
AMS 90mm Resonated midpipe
AMS 90mm exhaust
AMS Front mount intercooler
AMS 3″ intercooler piping
HKS bov’s
AMS Large MAF intake pipes
AMS fuel System upgrade
Cobb AccessPORT
AMS Custom Race gas map (unleaded 109 octane Race gas)
With these mods the car is putting 765awhp and 738 lbft of torque to the ground. Impressive stuff and big big numbers from bolt on upgraded turbos. What will we see when AMS’s custom cast manifolds and even bigger turbos get bolted up to Chuck’s car?
Taken from boostcruising.com.
Edited by NoFX_Hardcore
https://www.sau.com.au/forums/topic/313109-worlds-first-9-sec-r35-gtr/
They didn't do anything to the gearbox?
We worked with AMS in the US on this one and supplied them -
WR35TMVS our new high load 'Super GTR' transmission fluid
WR35PS GR6 Piston Seals
WR35CC GR6 Gear Fastener System
WR35CC-L GR6 Clutch Retaining Clips
This is not an advertisement, just pointing out there was some Aussie know how in that 9 second pass :ermm:
Please don't shoot me but isn't 9.89 sec actually 10sec in anybody's language other than a drag racer's? :)
I am fascinated how everybody calls an 11.99 sec pass an 11 sec achievement! No, it is not. That minor detail of 0.99 sec is 55m difference or 12 car lengths at 400m mark.
It does sound a lot better in the pub, I do admit.
Edited by GT-Ricer
It's an ET bracket. Ie 9.00-9.99, 10.00-10.99, 11.00-11.99.
when someone refers to "running 9's" they are refferring to breaking the 10.00 bracket....Circuit racers even do it :cool:
I would call it "running sub-10's" but it is a matter of convention, I guess. Thanks.
I was given one of these official RH9GTR stickers by Danny (of JMS fame) back in
2002 when I raced at the first Drag Combat meeting at Willowbank when the HKS
drag GTR was there running 7s. It was a huge honour to even have one of these
japanese stickers back then & there was no way I was going to stick it on my GTR
till I had the time to back it up. I ran a 10.9 second pass that day & waited till a few
months later back in Adelaide before I proudly displayed it on my windscreen after
running my first of many nines. (best I got back in those days - now over 7 years
ago - was a 9.45 @ 145mph)
All these years later, the fact that an R35 GTR can run nearly as fast with "light tuning"
is just astromonical. We spent hundreds of thousands of dollars to run those times back
then & there was no way our GTRs were street legal. Street drivable - sure, no problems.
My car was still "on the street" with Holinger, perspex windows, full cage, & 1 seat!!!
Awesome to hear that an R35 has cracked the sacred nines......... but dont be fooled.
There will be blood, sweat, & tears to keep it there. All those who see the number "9"
& take it with a pinch of salt - think again. The difference between 10.1 & 9.8 is huge.
There will be broken engines, clutches, etc etc. Mark my words....................
been there..done that.. Good luck trying to keep up with them.
A whole new generation of cheque book racers has emerged.
I will stick with my detuned 9 second R33 now turned into mid teens circuit racer
& leave my R35 as it is for fun & value factor.
Congratulations to AMS for doing it, keep up the good work.
Be interesting to see if someone will follow in their footsteps here in Australia.
Maybe the Willall R35 if we ever get a bloody Drag track again in SA?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
