what turbo would be best suited for a rb30
What do you want out of it? A 5557 .82 exhaust with the surge port (4 inch inlet, 2.5inch outlet) comp cover would be killer on the street. Billet comp wheel, twin ceramic bb core (that dosn't need water cooling). Super responsive 280-300rwkw
lol man, your opinion is based on stock twins! get a 5557, I dare you :D guinea pig lol
Once we sort the wiring/ignition problem on my guinea pig stock rb25/plain bearing 5557 combo, I'll be able to post the results... not long now.
It would happily be me although I am still in developement stages. Ive got a car and a motor, the two dont match yet.
Will be interesting to see how these 5557 turbos perform against a 3037.
Whats the rest of the setup the 5557/RB25 is going to be using? Manifolding wise etc? Completely unopened engine eh?
Yeah stock 100k rb25. It's currently hanging off a stock manifold with a wastegate adapter and 46mm PT wastegate.
I do have an HKS low mount manifold waiting in the wings if it works out ok.
650cc injectors, nistune, rb20 loom/ecu (in an r32gts-t), port matched greddy copy intake manifold, gtr cooler, n1 oil pimp, vct switch, 4" cat, hks super dragger, splitfires...
Actuall killing the same number coil pack right now.
J.
350wkw on stock manifolds, stock RB25DET, 52trim GT3037/GT3076R with .68a/r turbine housing - I could be wrong but you use a Dynapack as well?? If so, add some kw... not to mention potential gains from using better manifolds etc.
Just looked at Powertunes site, saw they use a DD... crikey. That suggests its a crapload.... very impressive result then. Thought it was a dynapack :devil:
Yeah dude, we nearly fell over! Actually it was a combo of 1) the power it made and 2) the fact the engine internally is bone stock (aside from drop in cams) and is holding together!
Wow thats some crazy results. I was waiting to see the results of the 5557 to see which one i have to buy. Was planning on buying the 5857 with a .82 rear for my RB25, now i'm not so sure what to get hmmmm.
What would you guys recommend? the 5857 with the .82 rear or .63 rear? or the 5557 with .82 or .63 rear for a RB25. My goal is 300kw maybe a bit more. Engine has CP pistons but stock rods, race bearings ect.
Edited by Girorostar
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
