anyone know of any GTR's running the PT6262 ball bearing with a T4 Divided .84 A/R with 3 5/8" V-Band discharge? would the .84 twin scroll be abit restrictive on the 26?
I have just bolted mine up today. The exact turbo u are talking about. Hoping to have it running by next weekend after i finish a 34 with PT5558.
I have fabbed up dump pipes for both and worked out cooler piping, plumb back pipes etc
This will be interesting Jez!
What's the specs for that 34?
Stock neo motor with Type B poncams and adj exh cam gear, link ecu with flex fuel tune, hybrid manifold, mvr 44mm gate, id2000's plazmaman ffp, DVS dump and plumbback pipe. Hoping to have it running and tuned early next week. Depending if Link arrives and also waiting on plazmaman plenum to be finished.
I was wondering whether you got the new turbo in yet, guess I have the answer.
How much boost are you going to run do you think?
That i will have to see what the engine likes when im tuning it. I will see how confident i feel with the power output as its a stock motor. Also running stock cams atm. I would like to see the differences in stock cams then type B poncams. Then i will think about doing variable cam once i have to upgrade the headgasket.
Very nice, shame its a stock motor as its probably not going to be able to show its real strength. I am assuming its a ball bearing 6262, and you are going to tune for E85?
Yes both are ball bearing. My rb26 i am trying to get as much response as possible which is why i went twinscroll 6boost manifold and .8 twin scroll rear. My old steelwheeled highflows came on hard around 4500rpm ad made 307 so i am aiming to better that
Yes both will be tuned on E85. They are actually both going to be be flex fuel tuned.
We understand the stock motors will be the limiting factor but not going to build the motorS until the time comes
Nice, very interested to see where it comes in - I've always had it in my head the PT6262 would be on the laggy side, though never been sure. If it can be all in before 4500rpm then that'd be fantastic :)
Are you going to stick with 2.5" out of the IC into the plenum or go 3"?
3 inch is pretty big Roy, I usually use 3 inch out of the turbo on builds over 400kw, I know it supports at least 550wkw from a car I did recently... 2.5 inch should be fine mate for either side.
I also fabricated piping for a built STI Liberty in 2 1/4 alloy, it runs 280awkw. More important is the cooler end tank design imo.
Just curious, mine are 2.5" and the numbers suggest that for 590cfm it should be fine with 2.5", but as always its interesting that the RB26 and GTR run 3" std
I see what u mean Roy, we will find out soon but i dont think the 2.5 will limit the setup. I think the only thing that will limit the setup is the standard internals
the engine will take allot of abuse with that turbo on e85.... :P just dont be scared. These turbos come alive at around 28-35psi.
Stre180 sr20vet made 'apparently' 760rwhp on a 6262 .63 housing it would want to be a low mileage 26 to even make 600whp reliable.
I agree it would want to be a "known" engine but really 600whp is a walk in the park especially for a few dyno runs....if it was my own personal car like it is with jez i would have no problem running it regulary at 400rwkw. We see this power quite often on std 26 engines on E85. I reckon in realistic power @ 35 odd psi 700whp is achievable with that setup but i would stay sub 30 on std bottom end.... i still find it difficult to believe that 760whp result with the 0.63 housing.
Interesting that you mention that, someone I know hit 400awkw on E85 at around 22psi with his unopened <100,000km old RB26 and coolant started escaping places it wouldn't, I had thought it should be reasonably safely doable too... good to know there are plenty of others which have done so fine.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
