Left it for now. Was up too 262kw at 5500rpm 14.5psi. Was just having a play tonight and good to hear it running.
Waiting on the new fuel system to arrive so we're ready for the eflex.
Surge tank and lines are on the way after ur very helpful input Matt. Cheers for letting us know about urs.
Fark im so keen to get mine on the dyno now.
Looks very similar to GT2871 results on a neo 25, I have a turbo that is highflowed with the same wheels that looks very similar to that graph though less power due to the restrictive rear housing.
http://imageshack.us/f/4/img20120517221202.jpg/
Be interesting to see how well this turbo performs when you finish the tune! Neos always seem to give fantastic results.
http://imageshack.us...0517221202.jpg/
Yeah.... Nah! It doesn't haha
Neo usually make a little less power actually because they are pingers
The few tuners I talked to seemed to think they always made more power as they seem to rev more, seen two results that seem to point that way, eg matt from nistunes r34 that makes 310rwkw on a 0.63 gt3071r with poncams on only 18psi, dyno sheet is on here from a reputable dyno/tuner, and then mine which is a highflowed rb20 turbo with the rb20 rear housing still that makes ~258kw on only 16psi
Edited by Rolls
On the same dyno for both?
Regardless from what i have seen, neo's seem to get a bit more compared to regular rb25det's with similar bolt ons.
Yep both on same dyno same tuner. Pete from nistune and the morpowa dyno in adelaide, he told me every neo he has done has gotten fantastic results compared to the r33 engine, "chalk and cheese" were his words from tuning multiple neo and r33 motors.
I also had identical everything just changed from r33 rb25det to a neo rb25det with the r33 intake, all the same sensors, hoses, literally everything the same just the block changed and went from ~236kw at 18psi to 258kw at 16psi.
Edited by Rolls
That's a solid improvement!
Is there any rewiring for sensors or the loom etc needed to put a neo rb25 in instead of an s2 33 rb25 or does just the ecu need to be changed?
The 34 looks like it will put up a good number, I think you'll shite 400kws in Jez
Im curious to see when this turbo maxes out.
I know Kurtis is now a power junkie but this thing is aimed at max response with strong top end. I have the goal set at 350+.
Time will tell with my one too. Its a 700hp turbo. But same again its main goal was response and 380+
He'll make it, i have faith! Its a 700hp turbo vs my 550hp turbo and i NEARLY made it, so you guys will make it for sure :D Cant wait to see, its sounding good!!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
