Isnt this turning out a little excessive for sub 400kw?
I wonder why it needs so much flow, le hmm.
Sorry mate
Didn't realize I was spending your money,
Flow is no longer in question Jez have spoken with e85 guys and they believe it's related to the fuel heating up to much second pump is to help with said issue
I think what he meant by excessive was its seems odd that your fuel system isnt coping as well as others have, I dont think he was talking about cost.
Eg some people are getting enough fuel flowing to make around 360kw on e85 using a single 044 intank with standard fuel lines and you are having to add a surge tank, bigger lines and another fuel pump. Granted I dont think they are going to be putting out quite as much power as you when your tune is finished and they werent running as much boost, but still.
Edited by Mitcho_7
Sorry mate
Sorry WHAT?
Dont be so defensive like im mocking your hard earnt layout. Good luck to you, I hope your stuff turns out well, I message Jez on the regular and get updates on how your cars coming along. The way you replied to that is almost offensive.
Mitch above is on the money. Im simply curious as to why its needing so much flow, and in a perfect world that could have lead to discussion about what other people have flowed with what setup. Who knows, maybe a few great minds would have joined in and helped troubleshoot so you can find out whats going on.
Spending my money, pff.
:no:
360kw with single pump is the limit.... Well 357 was the final SAFE number anyway
Standard fuel lines were all over and done with above 340ish.... I had to go bigger lines and modify the fuel tank hat...
:no:
This I was not aware of
GTR/GT-t = same last time i checked... Wonder how the GTR guys are getting 400rwkw+ through stock lines & E85 (with just a Nismo pump) :unsure:
I think its a lot to do with the fuel hat itself.... It was a restriction.... Hence the modification :)
355rwkw here on pump98 and single pump no restriction. and 335rwkw on eflex no restriction all stock lines and rail. in gtst.
Well i dont want to go dribbling shit without properly understanding it myself BUT on my car the fuel pressure was unsafe at 360kw, after the mods were done and it was rechecked the fuel pressure was spot on at 357kw so it was obviously a restriction...
My original post from page 30 said exactly that.
Then I edited it in fear of a flaming :P Thanks for putting it out there though, I knew I wasn't going mad.
Sydney is warmer than Mexico. We need stuff like 15 litre sumps and 3 fuel pumps. :woot:
Hahaha exactly.
Maybe this will make a few people scratch their heads.
hehe :)
I'm a bit behind on reading all threads at the moment. Too busy, so i tend to miss post replies where I usually see most even pre-edit :P
Nismo outflows a 044. Im hoping my single walbro 400 will be ok otherwise i will mount a 2nd pump in tank
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
