Very first pull on the dyno, well once i changed to a 7 bar map sensor. I used 16psi springs in my twin scroll manifold. But for some reason 22 is my low boost. Its a major job to get the wastegates off as i have plumbed them in and very little room to work around.
On this run i backed off at 6400rpm
Overlay shows my previous best with -7 copy twins.
Both on E72, both have same tyres etc etc. the e72 in the tank atm is 6 months old
How about some rpm scale love there Jez instead of road speed?
All looks promising so far - I bet you're happy!
I can try for u stevo but its only roller speed and i can input what rpm at a certain Speed if that makes sense. I mainly use it as a reference. Worst part is it doesnt save each time the dyno is on so i cant do comparo's on different days with rpm.
Gotta be happy with that jez
Very. Cant wait to push some timing into it. Think i might stop at 420ish kw. As stock engine and cams
Yeah that makes sense, fair enough.
When's more tuning going to happen?
Putting fresh fuel in for that?
Would be great for someone to do back to back testing on a range of these things. Eg 5557, 6262, 6466 etc all on the same engine, same dyno
I think I put a link in here a while back from some guys who did just that, albeit on a 3.4L jz
What twin scroll manifold and gate/s are you using for the precision Jez?
6 boost manifold twin tial 38mm gates. Custom dump and plumb back piping.
Stevo hoping to get the rest tuned on e70 sunday. See what boost i need for 420kw. Then wsid for a 1/4 mile run to see if she holds together
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
