4th gear stopping before limiter. I have alot of mechanical sympathy :)
Limiter is 8k. I like my stock rod bolts non stretched :D
Hmm. Something is up. 4th at 8000 RPM is 235 km/h and you're going to 190 ish km/h which is 6400 RPM. :S
Could the road speed on the dyno be wrong or something?
It's only my gay 4door gtt that needed so much fuel system work
But hey Can't complain with 367 @the wheels
At least your gay gtt runs ya kent :P stupid flex fuel!!
Nice result so far! Though to be fair I'm not sure if the PT6262 will really be showing its mettle yet, have you had any stock RB26 with a GT3582R on E85 on that dyno? That would make for a very interesting comparison
No i havent. This is the first single on rb26 on this dyno.
I wish i had a forged motor so i could run 35psi. I think it be close to 500kw
took it for a cruise to get some pizza. Without finishing the tune down low it drives very nicely. Below 3 very little boost. Above it picks up nicely.
So are the Precision turbos their own CHRAs or common with Garret. I am looking at either a FP73HTA with one of these housings but also considering a Precision turbo...but makes life easier it i can run one of these rear housings
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-HSG-075&Category_Code=
Has anyone worked out the rpm vs speed yet..?
How fun would that turbo be on a 3lt
PT6266 would be more fun :D There are quite a lot of Supras running them, they seem like a pretty brutal all around setup.
Off topic, Jez u get the pic etc? I have the same issue as Kurtis :(
Hey buddy, yes i got the pic. Very dissapointing i was sort of hoping it was an odd issue with Kurtis's car, but if its happened on a different car with another workshops setup makes it very annoying. Hopefuly warranty wont be an issue.
Txt sent
How does the turbo sound when your up it Jez?
I've been told they are rather quiet compared to most singles...
On the dyno from in the car with headphones on i couldnt really tell. U can definately hear it spool up like a jet when inside the car but i havent been incar with a similar setup so cant compare.
No prob Jez , just put it onto mine and see what it will make :)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
