The 6266 would match the current power on some decent boost. But if u want to out power the T51r u may need to use a 7 series PT.
What are u going to use the car for? How laggy is it now?
Was planning to use it at the drags here in Tassie but looks like our track is closed down.
Its making 24 psi @ 5200 but my exhaust system was restricting it.
Which box is it exactly? I'd be more inclined to go a 6466 or 6766, if it's a power sucking C4 :) They are rated at 900/935hp.
I have the power sucking C4 :rolleyes:
if the 6262 goes 500 it must be the best turbo in the world, response of factory turbos and power of a large laggy heap of crap.....
I'd like to go up to Jez's dyno when my engine is done. Put it on there for 2 or 3 power runs then overlay it. From whats been shown so far, it could be big single time ;)
FOR SCIIIEENNCEEEEEE!!!!!!!!!!
Sorry, couldnt hold it back. Now do it.
I am sure a 6262 could do that power on a DD, and that would not make it the best turbo in the world imho as there are others in similar territory. Here is an old example of what these turbos can do...
I woudn't look to AWD motorsport stuff to see what that would do(or any precision)..lol, unless you want to run no gate and
let the sucker make what it makes..lol, he did that on supraforums to a customers supra aswell,, 7675, making 7680 numbers.....and he did it to the record setting lancer in the video above , the thing apparently nuked itself not long after
I like his attitude and his balls though, haha
cheers
darren
Edited by jet_r31
cheers
darren
Of course that is kill mode, but that's serious business for a 62mm turbo without nitrous oxide
76mm compressor, garrett Gt42 S trim turbine(aka 4202), so sameish size as what you have( or same size as GTX4202), but if you have no
track i'd go smaller, be a toss up between a 6766 and a 7175 i reckon..
cheers
darren
Edited by jet_r31
PJ, what have you seen the 6262 and/or 6266 go to power wise?
Will the 6266 crack 500?
A 6266 will crack 500rwKw all day on an efficient engine. A mate of mines car made 491kW on a plain jane GT35 with .82 T3 housing, then went out and ran a trap speed of 147mph, 1400kg car including driver!!!
Yeah that sounds more like it Lithium, 900whp is a MASSIVE number given the size of the compressor and turbine wheels
My 6766 peaked at 853hp on Mainline at 42psi, running it any harder may have just caused drama's so we called it a day.
The yanks have gone very fast with these turbo's no doubt, they also have the cars setup to take an absolute pounding. I believe they have gone as quick as they have without any GST on the story, I still find it amazing how they are going 145+mph on FP Red's though.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
