Guys....just changed my mind again..not buying a precision... :whistling:
Waits for half of SAU to slap him..... :whistling::whistling:
NAH ! Just put my order through now through paypal. Precision CEA Billet 5558 0.63/T3/V-band plus two silicon joiners $1045 usd delivered to SYD. Wooooott ! ! ! Done! Hurrah.. lol
Were you sweating a little bit as you clicked that button, Ron? :P Lol just jokes mate, looking forward to results, good stuff on finally committing!
I was sweating like a pussy when I clicked that button Hanaldo, and Jase, ur welcome for a ride when done mate, but I'm not a errm..extremely safe/cautious driver..ask err Jez. lol.
lol well making the car even faster is not a good way to become a better driver IMHO.
i generally advise people to thrash the life out of something underpowered to improve their skill. i dont have any advice for you with a 5558 powered NEO :P
All the ones i have done have made big power on 22psi. Havent needed to go bigger boost as of yet
Will be tuning sr20 with 5558 external this week or next. Just running motor in
How did you go with that 5558 on the SR20? Ball bearing or journal? Do you have any further information relevant for SR20? (thanks in advance!)
I just bought a top mount T3 external set-up with 44mm tial gate but minus turbo and am trying to work out what turbo to go for (who isn't :wacko: ).
Currently makes around 270rwk out of a T2 3071 internal gate on 23psi with E85 and Tomei 260 cams, standard bottom end for now (Unigroup dyno) so I obviously want more than that, actually a lot more than that - ie ability to push to 350rwk later on. Unfortunately, it still has to retain reasonable response for a track car (very irregular street car) which makes it a bit trickier.
So far have narrowed it down to;
  • 5558 journal or ball (55 exducer, 58 inducer)
  • 5858 journal or ball (58 exducer, 58 inducer)
  • TD06SL2-20G 8cm (3" inlet, 52.5 exducer, 54.1 inducer - think it might be too small as most results seem to be around the 250-295 mark)
  • TD06SL2-25G 10cm (4" inlet, 60.5 exducer, 54.1 inducer)
It seems the 5558 will make the numbers but on high boost (not good for standard bottom end) and the 5858 will make it easier but will sacrifice some response in doing so (not good for turns 2, 9 at EC and fish hook and last corner at Wakefield ;) ).
Currently leaning towards the 5858 ball bearing but not sure about the response it will give.
jump on NS.com and have a look at DRE20's car, he has a 5858 and the dyno plot makes it look fantastic. very nice and broad powerband. Do this if you really want that 350kw 'down the track' setup.
FYI the TD06SL2 20G is a smaller turbo than what you have now and the TD06SL2 25G (T67) is more of a 6cyl oriented item.
If you simply buy a T3 .63 external gate housing for your current turbo and retune your car will improve everywhere. You should crack closer to 300kw and response will also improve. This is what I recommend you do.
If you want to sell your 3071, please PM me.
Yeah I never thought of that! I just put a brand new rear housing on it a year or so ago. But I think I will sell it.
Yeah I'm on NS and have seen the build. Scale is in speed so hard to tell but the graph does look good. Its also a large bore engine with 90mm pistons.
http://www.nissansilvia.com/forums/index.php?showtopic=516776&st=60&p=6623610&hl=precision%205858&fromsearch=1entry6623610
There's also Joels 5558 BB. Hard to tell what its like with the graph he has put up though.
http://www.nissansilvia.com/forums/index.php?showtopic=521707&st=30
NYTSKY: Is that not what Hi-Octane were running on their R34 at WTAC?
I think it was a 65, could be wrong.
The 32 had a 6262 on it and was absolutely flying. One of the better sounding cars there too.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
