Nothing that hasn't been done before Darren, Just not on a street car! As long as it doesn't fall off boost between gears it should be ok, remembering that can rev this to over 10 grand if I have to, I'd prefer not to though.
  • Like 1
I was about to say "Now you're just starting to get silly..." but really, that happened quite a while ago. That thing is a beast to watch, was glad I got to see it running in the flesh!
Should have said hi, Lith. Unfortunately I wasn't on top of things with the boost control at WTAC, the street and circuit grip level was completely different. Before the hairy last session we even took it outside and tuned it to full traction, then turned it down again for a bit of assurance.
It turned the tyres on the first run, so in between runs, not being able to look over the log, I took a stab at what speed I thought it was breaking out. What I ended up with was 22psi all the way half way through 4th to an agro 45psi which lit the tyres up. Being such a big event rather than pedal, I mashed it and held it flat, and a slight over correction when the front wheel speed was doing 220km/h and the back doing more like 260km/h sent me facing the walls....at least the crowd loved it!
We are revving it to 9000rpm over the line at 164mph.
PTE don't make a TS housing yet, I was speaking to Harry when he was here for the Nitro Champs and they don't feel the demand is big enough.
I actually headed past your area a couple of times to say "Hi" but wasn't sure who you were and the moment didn't seem right for a random to push in and say "Who is PJ???" - then next thing I knew the weekend was done, it really was a blur of an event.... went past so quickly it wasn't funny. First trip to Oz was a goodn' and I'll be back, hopefully just get to see an even crazier S13 :D
nah, we havn't, i was walking next to Maatouk at jambo and turned around and saw you, was just about to introduce myself
when Anthony turned around and said PPPJJJ and started talking to you, i just walked off as i had only just met Anthony but
already worked out 2 things,once he starts flapping his gums, i could have been standing there for hrs waiting to talk, and 2
if he ever gave up on working on cars, he could probally make money of a stand up comedy gig..lol.
maybe next time lol
cheers
darren
Just ordered my 6262 with a T4 twin scroll .84 v band rear and the 4 inch surge slotted front.. lets see just how strong a standard 25de neo really is with 10:1 comp and e70
Aww shit, this should be interesting. Or hilarious. Either way, exciting :P
still ecu and the stupid stupid expensive job of doing turbo lines and fuel lines which is gonna be a surprise $700 in fittings and hose.
Looked at the AI industries surge tank with twin 044's today too but thought f**k it single intake walbro it is!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
