attachicon.gifImageUploadedBySAU Community1396264885.717947.jpg.
4828,s pictured with expreme manifolds someone was intending on bolting on a rb26........
seen this picture before, is it from a for sale thread lmaybe ?
Anyways, I bet they are not since I wasnt able to find any info about them on a skyline/rb platform.
7675 comp covers.
gt42 style vs hp.
different surge porting.
different outlet.
is the 42 really worth an extra $700?
im assuming they would have the same comp wheels.
anyone had a play with them?
Was leaning toward the EFR 83/74.. but my mechanic told me th journal bearing shouldn't be any laggier/sluggish than the same turbo with DBB. what,s your take on this for a 6262 ? With the journal worth 1100$, its a 1100$ +tax/duties saving over an EFR, it's worth considering haha :)
Its a matter of you get what you pay for.. Most guys in here are using the DBB option and paying over $2000 a turbo. I think it would be naive to a degree to expect to obtain the same results with a turbo half the price. Whilst I have no doubt their Journal Bearing option will still be ok, If i purchased one I wouldnt expect the same results as the DBB ones.
R
R
This is what I though too, but since I have high regards for my mechanic and some drift driver sponsored/great deal by PTE use his mechanic service so I thought his opinion about PTE turbos should be right. so MAYBE... journal bearing improved a lot in the last few years... I don't know lol.. this got me confused, but tbh, if I'm going to pay 2000$ for a PTE DBB, I might as wel bite the bullet on the efr I think :)
You are over-thinking it, the turbocharger should be sized appropriately (using a compressor map) to your engine... bearing type should be one of the last considerations.
Put it this way, I bought a Borg Warner S366 which has very similar size and design turbine and compressor wheels as a EFR9180 but is journal bearing and doesn't have the fancy material compressor wheel, wanky & ugly (IMO) BOV in the compressor housing. Cost me all of $750.00, flows the air that I need at the required pressure ratio.
Edited by bigmikespec
  • Like 1
7675 comp covers.
gt42 style vs hp.
different outlet.
It's twin scroll divided housing vs open. GT42 style also has a larger comp cover, that's the difference.
can get both with a t4 divided rear.
gt42 with 0.96, 1.12, 1.22 options.
hp with 0.81 and 0.96 options.
the exhaust outlet is bigger on the gt.
gt42 is obviously a larger front cover.
but, considering the same rear housing (0.96), would there be any difference to spool time or outlet temps?
has anyone done back to back testing?
I know an awesome tuner that now loves bolting precisions onto RB's and adding some E85 and some other magic and numbers happen :yes:
Hi Noy
Been waiting to see what the end result was. Any updates or did I miss it?
I am having PT6262 CEA SP installed this week
  • Like 1
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
