  • Replies 69
I saw a Rex with a sticker like your signature and saw the 'Require 2 Balls' (should that be 'Requires'?)... made me laugh. Vroom!
haha. The 'require' is refering to track days 'require' 2 balls.
UPDATE
I can confirm the replica of the Winfield R32GTR will be on display at the General Meeting. The car recently took out the prize at the Formula 1 Autosalon Grand Prix display.
Owners, John and Scott will be available to answer any questions etc.
(Thanks to Bez cos I stole his photo :))
The Digital SLR is coming for this!
Keep car clear for me :ninja:
... Ah wait, lighting...
Need good lighting... Hope it is not too dark, I might get there ASAP after work around 6ish...
why dont i just bring a flash?
Yeah I will.
You gonna bring your camera too?
I remember you take a few pics too.
just up your ISO a little and use longer exposure, night mode not needed. what camera do you shoot with again?
Canon EOS 400.
Yeah, true that about upping the ISO, it goes quite high too.
:ermm:
just don't go too high, or noise will be rediculous... unless you have noise ninja on your PC then up up away
Yeah , should be fine, I will trial different levels of the ISO till it good.
:D
hey guys bad news i cant bring the car due to having the trailer stolen on Friday night sorry about this but all i can say is thanks good they did not get the cars!!!!!!!!!!!!!!!!!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
