on swaybars....actually for anyone new at the track....
most important thing (apart from learning how to drive around the track) is to get your tyre pressures right first.
frist thing decide target tyre pressure. If you don't have a specific number try 38 for road tyres, 34 for semi slicks.
It's wakie and its winter...so start with the following cold tyre pressures:
RF target -6
LF target -8
RR target -6
LR target -4
don't worry too much about the first session, just feel your way around the track.
second session give it a warm up lap then 3 hard laps, then come into the pits pretty quick (let the brakes cool a little but don't back off on the tyres). come into pit lane, pull to the side, leave the car running/out of gear/handbrake off.
let the tyre pressures in each tyre down to the target pressure.
then go out and enjoy the day!
Once the tyre pressures are right, if you have adjustable bars set them both to medium. if you get too much understeer back off the rear bar to soft. if you get too much oversteer....maybe try softer front bar, or more front torque if its adjustable, or turn in later, or more progressive throttle out of the corner. If it rolls too much go harder on the front bar. but basically change them from session to session (pretty easy) and see what you like :bunny:
Remember each 3 hole bar has 5 settings because you do not have to adjust them evenly (ie you can have "hard" on one side and "medium" on the other to create "medium/hard")...so there are plenty of settings to confuse you!
hope you got the wheels aligned before you went to the track!
  • Replies 566
nah all good bobby, 8 year old ACL rupture that ive been putting off but know its giving me grief all the time so biting the bullet.
about the car, if you guys are serious about running it im happy too have it ready as i want to test the new sump. have already asked Ando but he reckons he might be too busy.....scared lol.
PM me and let me know. Besides i want to hear it from track-side.
Bring all your tools, and any spare parts you may have.
Bring spare coolant, oil, brake fluid, power steering fluid etc.
You will much rather have it, and not need it, then need it, and not have it...
Ill be bringing my big trolley jack, might bring a few peices of wood for u very low ppl.. trolley jack is 70mm when lowered..
Full Name: Reece McIntosh
Car Type: Clio
Newb or not: Rookie....
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one): 1.11
# of Drivers: 1
# of Passengers & Name: TBA
I left it late, but I will be there :bunny:
yayyy Reece!
and OMG....8 years and Shell enters a track day! You'll have a ball :bunny:
haha it's the first time I've had a "spare" car (even if its a stockers POS) so I don't have to worry about how I'm getting to work on Monday if anything breaks!!
orly? Never considered that! Thanks Druncan :D
same...happy to take it for a spin stu!
dave, don't worry there will be plenty of tools there on the day...haven't you met the exec committee :thumbsup:
and OMG....8 years and Shell enters a track day! You'll have a ball :rofl:
See what fresh blood on the commitee does? We get everyone involved!
Car Type: Clio
# of Drivers: 1
I left it late, but I will be there :thumbsup:
about time!!!
Pfft, wouldn't matter what you use, Reece... You could probably put us all to shame while you're riding a Big Wheel - who's old enough to remember those, btw???
Looks like I will only be coming as an "assistant" at this stage. I could get the car going in time but it won't be quite right... and experience tells me that the only outcome from "not quite right" is disapointing and usually quite expensive. So I have decided to leave the girl parked in the garage, where she can't break anything :blush:
I am hopefully still going to come down and if I do am happy to help out where ever I can be used. Last time I had a lot of fun at pit exit ensuring that Neil and JP happened to find themselves rubbing elbows for the same peice of real estate. :) Although this didn't help me find my way out onto said real estate even if in the passengers seat. :)
Passengers can go into other cars, however I'm pretty sure there are quite strict rules about camera equipment inside cars.
Last i checked, a photog holding a camera and shooting while someone is driving, was not allowed.
Ando, correct?
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
