chop the tops off the rear 2 subframe bushes. This will slightly increase squat and won't shock the wheels down to the road as much wen u dump the clutch.
Interesting idea, so is that similar to setting the pineapples up in a squat position?
My only counter question to this is why would solid mounting the subframe be the ultimate to stop axle tramp if the issue was squat?
  • Replies 89
Posted Images
Just a thought but you said it was the lower control arms that improved the issue. Now I figure that the new bushes will be better at doing the job they're supposed to than on old set. The thing that I want to know is what was the alignment before and after changing these? Geometry will play a part in inducing/affecting axle tramp in some way. If the new bushes are adjustable and you now have the alignment good, were you able to achieve the same settings with the old ones?
Diff bushes will take a little while to change but for a suspension workshop it shouldn't take too long with a hoist. The painful part is when you're crawling around on the ground to do this. Maybe change the fluid while you're at it? Changing the 4 subframe bushes is a big job.
Good Luck
Lots of info in this post! Just trying to decipher it all.
First question about alignment, the car was aligned after every stage of work. Chris at Centreline made a point of mentioning it and I also paid for it.
I dont believe the bushes are adjustable but could be wrong. Not sure about this question.
Are you saying that diff bushes are easier to change than the subframe bushes? That would be good because I think the pineapples are doing enough to tick off the subframe bushes.
Do you mean changing the diff fluid while they change the diff bushes? It has brand new redline diff oil in there.
It's a combination of both subframe movement AND squat. U should NEVER lower the subframe in any way. This lowers ur already too low roll centre. Putting pineapples above the front bushes for squat does this. A much better alternative is to raise the rear of the subframe. Then you're fixing squat without lowering roll centre. Less keyboard more car. Just do it lol.
Edited by bradsm87
I have my pineapples set to all round performance (both on the bottom):
http://www.whiteline.com.au/instruction/203a_KCA349.pdf
This would not lower the subframe, if anything it would raise it slightly.
Also my car is not that low, ie 350mm centre of wheel to guard.
Found this but looks very major work and more for a track car:
http://www.skylinesaustralia.com/forums/Su....html&st=20
Edited by Harey
If you look at the images you can see between standard and all round performance that the subframe doesn't move. It isn't higher or lower the pineapples just go underneath to help stop some of the squirm/movement caused by the rubber subframe mounts. by grinding off the tops of the rear subframe bushes you are effectively doing the same as the max traction setting but instead of lowering the fronts by putting in a pineapple you are raising the rear. Since the urethane pineapples aren't solid there will still be a little movement and give there. This means that there could still be a way for the rear to store and release energy in the form of axle tramp. obviously there is a change to standard so this will change when/if it occurs. Any flexible joint in the system will add to this which is why some suggested the solid metal pineapples to do this. It effectively locks the subframe in place. There is a down side for street cars though as without the nice
new subframe mounts may solve your issue and help tighten up the rear. I hadn't looked up their website in a while but there is now an online catalogue for the Whiteline Plus range here. Your subframe bushes look like they'd be W92446.
I figured you would have had the suspension alignment done after all your changes but were they all the same settings? If your new control arm bushes are adjustable they allow you to achieve more or less camber etc. The new ones might be allowing you to reduce the amount of negative camber that you had previously helping to reduce some of your issues.
I used to get tramp with Bilsteins, Whiteline springs, 19x8 rims and 245 tyres on my R33 GTST but I don't anymore. I can't say I really went about trying to solve it though. I have changed most of the bushes over to Whiteline adjustable ones just to freshen up the rear. I have pineapples in all round setting (I think) and have replaced the front diff bushes. The rear ones need to be pressed in and out I think, front diff ones might be possible to do on the car?? I've got 18x9 rims with 265 tyres at the rear now.
Thanks for the info. Diff bushes are definitely next on my list. I think I have done everything else.
Interesting thing to note is that if I spin the wheels out of a corner it doesnt seem to axle tramp, just nice smooth wheelspin. It only seems to happen in a straight line.
Does that point to anything?
My thinking is that the suspension only gets loaded side to side instead of front to back when it squats. So my side to side suspension must be ok but not my front to back. Hmmm diff bushes are front to back...
i dont know whether a gtr is the same? but we use get shudder that appeared to be axle tramp alot, it ended up being the tailshaft centre bearing everytime!
we replaced it regularly but in the end we went to a one piece tailshaft.
hm this is probably stupid .. but I haven't had my dose of stupid things to say today so here goes.. Are you sure the tyres are on the correct way ? The KU36 have an inside and outside wall and I'm thinking if you put them on the wrong way around ... I only mention this because I just read another guy's thread where he wasn't sure if he put his KU36s on the correct way.
  • 1 month later...
Hi Jeff,
Just reading your topic: Do it right, do it once and be done with it if you plan to keep the beast!
Source a non-hicas cradle from a 34 GT in good cond, sand blast and paint as new, buy new uprated cradle bushes $220 get em pressed, purchase new diff mounting bushes front/rear and get a new sleeve made for the rears to accommodate the new bushes or source an aftermarket one that already has the sleeve.
Take a week off work, remove old cradle and diff end, re-do all your rear suspension bushes if not new already, clean down and paint all your arms etc.
Put back together in the right position with pineapples and hey presto, your rear is like new again, but better than before no-hicas and will look great in nismo silver, or black!
Then do the front after your back recovers from all the hard work! LoL!
Just my 50cents worth and a good project to keep you busy!
  • 3 weeks later...
I just replaced my diff bushes (rear two that bolt to the diff cover) with the nolathane kit and it fixed 95% of my axle tramp. Only time it tramps is when the KU36's are cold first thing in the morning. Even then its not a gearstick shaking tramp like it used to be.
I went about fixing my axle tramp the long way, I originally thought it was because of leaky/worn diff cradle bushes on my R32 gtst, I did the math to pay someone for labour to press out & replace, didn't like the idea of pineapples or solid mounts, worked out cheaper to buy a whole rear end from a GTR with diff & bushes that were ok and swap the whole thing myself it myself without press out the bushes. Long story short, rebuilt the GTR diff, removed hicas, whacked it back in, took it for a drive & axle tramp was still there even with the diff mounted solid at the pinion end to the cradle. Drove it round for a week, deff didn't fix axle tramp, next weekend dropped the whole rear end out again, pulled diff out & cut old bushes out using hacksaw. Had to remove some of the rubber of the old bushes with a drill where I was trying to cut because it kept binding up on the hacksaw blade. Probably only took 20min to do both witht the cradle out. They fell out with a tap of the hammer, no press needed. New ones are just greased up and fell in, no tools needed. You could probably remove the old ones without dropping the whole rear end but in all honesty it will probably be quicker, a lot less swearing & grazed knuckles than trying to do it lying under the car with a hacksaw blade wrapped in tape from only one side. There isn't alot of room to move if you do it whilst still under the car. I did the whole thing in my garage with one trolley jack & a mate to help me line it up when it came time to lift if back into place. If you have access to a hoist then you will be laughing. I think the kit cost $130 from Repco, best money i have spent, PM me if you want anymore details.
Cheers
Rob
Cheers
Rob
Thanks Rob, I just purchased some nismo diff bushes (all 4) and will get them fitted hopefully next week. I think that is the last standard set of bushes remaining in the rear.
Picked up my car today with all new nismo diff bushes and AXLE TRAMP IS COMPLETELY GONE NOW!!! WOOHOO!!!
Transitions from quick takeoff to wheelspin really smoothly and does not axle tramp at all.
So in summary diff bushes have to be high on the list, with pineapples or full subframe bushes as the top two contenders IMO. Start with those two things first and then see how you go after that.
Thanks for all the help I have received in this thread, hopefully it helps a lot of people in the future!
If I launched with 4,000rpm while slipping the clutch for a smooth launch would result in wheelspin but good movement. Anything more was heavy wheelspin and I would have to backoff to get the car moving.
I did get the tyres up to temperature before doing this. Also a very smooth road.
If your about quick takeoffs on the street with a rwd then i think you should stop at ~200rwkw. If your more after second gear plus runs then keep going in power. I am sure with more power you could just launch with less throttle and still get away ok but i doubt you would beat the 1st gear of a std turbod car.
I expected more too! I thought i could just give it hell on a launch and the tyres would laugh at my power.
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
