  • Replies 139
yeh internally gated low mount for me was a must to avoid defects... thats why i went with 3071...
mine doesnt hook up to the standard skyline dump... i have custom intakes n dumps... (dump made a big difference)...
got some pics too but not on the work comp so will prob put some up on the weekend
this is the pickle i was in for so long, personally i dont like the results the garrett IW housings give.
if i was going thru this again with an RB25, i would do one of two options:
HKS 2835
or
3071 ex gate .63 rear. id send my housing to hypergear to have it moded and a gate added.
im confident the ex gate 3071 option i just mentioned would be one really REALLY awesome option for an rb25, infact i wish i had done it myself (now going hks 3037 and rb30 to compensate)
fun and games all around
dont most of the hypergear stuf like the atr43 renge use .70 a/r comp cover. what size is the standard one
cant remember off the top of my head. ask Tao from hypergear or check the site maybe. he knows all the specs.
I should of mentioned that the high-flow i am referring to is with either a VG30DET or RB25DETNEO turbo (OP6).
Hey usmair!
Got a dyno sheet dude?
Surly having the stock tubby rebuilt with steal internal and high flowed with a custom ecu remap will be cheaper?????
I got 300bhp 220kW with my silly set up and im sure you could get at least 30 or 40 bhp more out of it if I went the steal tubby and ecu route.
  • 2 months later...
Hi Guys,
After doing some searching I got to this thread ..
I'm looking for a turbo that fits right in (but wouldn't mind different water/oil line), spools up quickly (3000 rpm) and will keep me happy for a long time.
My target is about 350-400hp at the rear.
I want minimal lag!
The car will be used on the road with some drives to the drag strip.
I hear mixed things about these high flowed turbos.
A company here sells these:
High Flowed
(I need compressor maps for these)
I want to keep the internal waste gate.
I know this has been debated a zillion times, but I just lost track of the many options.
:blink::P
Thanks for your thoughts,
Andrew
Edited by Torques
go read the rb25 turbo upgrade threads, pick the best looking linear curve and your done
saves all the guess work and trial error
Thanks .. I know this one ... as I said there are a zillion posts about the topic.
Some pictures from last weekend
Edited by Torques
this is an HKS 2835 pro s (HKS modified garrett 3071 with a .68 rear)
it is roughly what most of the turbo's mentioned in this thread will look like when running a fairly aggressive tune on around 20psi
the red line is bp ulimate and the blue line is e85
just wondering, everyone's always talking about upgrading turbo's and what not...what about just hi flowing them? i know they might not make as much power as a bigger turbo but they'll still spool pretty quickly and can still make good power if tuned right with good bolt ons
I bought a HKS GT-RS.
Its untuned at the moment, running on a reset Power FC and using the standard ~1 bar actuator to control boost. Feels slightly laggier than standard, but with a much torquier midrange/top end.
Its getting dyno tuned on Monday hoping for 330rwhp, I'll let you know how it goes :)
Hey usmair!
sorry for the late reply
unfortunately the car has now been sold so I cant take any more pics
I did have one of the engine bay here somewhere... If i find it i'll chuck it on
If you are happy with 250rwkw and loads more response, the HKS GT-RS is an option. For the money tho, I would prob go a GT3071
GT2835 PRO S @ 18psi on an rb25 saw full boost at 3200rpm made something like 340hp on a very safe tune with a very tied engine
or
buy my HKS 3037S Kit make easy 400hp+
Edited by Kaido_RR
  • 1 month later...
what boost tho? the 3076 will do same power and response times... but less psi needed to make same power.
Ive had both type of turbos on rb25's so bit of experience with them.
My 3071R was a AVO or ATP style rear housing to bolt up to skyline dump. mounted lowmount and made 280 rwkw on 20 psi.. i then ran cams and made same power on 17 psi and spooled earlier.
currently have 3076 but with garret rear and ex gate, full boost at 3500 and makes 310 rwkw on 17-18 psi, stock cams.
Sorry to dig up an old thread but that is not fair to compare a turbo with a 6-bolt housing to bolt up to standard dump and a genuine garrett housing.
It has been proven many times the genuine garrett housing will outperform the modified ones (to bolt up to a standard dump) in every way.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
