Big shame that shitfight has gone on. Great concept with crappy administrators.
Still - I for one will be forever greatfull for their existance. If it wasn't for them I'm sure I would never had the chance to drive some of the cars I did.
Had a quick read, i'm sure James has got nothing to do with it.
I'm sure he's got nothing to do with the trouble itself (and hope I didn't give that impression), I was just wondering if he still worked the Melbourne Supercar Club or not (I'm presuming it's the same company, how many supercar clubs could there be?)
Poor old James, thats a major bummer. I was really hoping to one day be a member once I had that sort of cash to play with. Hopefully an investor steps up and buys up the company if managed correctly its clear it could be very profitable. Maybe James could be the boss :(
agreed - me too!
Likewise.
I hope James doesn't come out of it too badly, he's a deadset legend and shouldn't be punished/disadvantaged due to the bs that happened that was out of his control. He put in so much effort and time that was above what's required for the members.
His phone just goes to a voicemail message now.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
