you know...I might just have been unlucky, but I have one of those, not too much use (just home, not workshop) and it is leaking. Really not what I was expecting for the price.
That's not good to hear :/ . But my local Snap-on man has been excellent with warranty/exchange in the past, with no questions asked. So I would have no qualms returning it if need be. Do you mind sharing where you got yours from? Is it just weeping from the seals or leaking badly?
Mine leaks too. Back seal on piston. Bought a 3 tonne Omega at around the same time - no leaks.
got a set of these a few weeks ago
http://chadstoolbox.com/3x8603knipex3pcplierwrenchset710and12.aspx
I use them at work for steel wire armoured cable glands however I can see them be very handy for heaps of jobs. they work just as well as a spanner in regards to gripping bolts and leave no marks.
every workshop jack ive seen over 3yrs that isnt serviced has had leaks.
Thanks for that observation. How many workshop jacks are we talking about? My Omega doesn't leak and is a far better product in my opinion than the Bluepoint/Snap-on. I have both, as mentioned earlier.
approx 8+ different brans.
2 being omega.
1 of those omega leaking.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
