you know...I might just have been unlucky, but I have one of those, not too much use (just home, not workshop) and it is leaking. Really not what I was expecting for the price.
That's not good to hear :/ . But my local Snap-on man has been excellent with warranty/exchange in the past, with no questions asked. So I would have no qualms returning it if need be. Do you mind sharing where you got yours from? Is it just weeping from the seals or leaking badly?
Mine leaks too. Back seal on piston. Bought a 3 tonne Omega at around the same time - no leaks.
got a set of these a few weeks ago
http://chadstoolbox.com/3x8603knipex3pcplierwrenchset710and12.aspx
I use them at work for steel wire armoured cable glands however I can see them be very handy for heaps of jobs. they work just as well as a spanner in regards to gripping bolts and leave no marks.
every workshop jack ive seen over 3yrs that isnt serviced has had leaks.
Thanks for that observation. How many workshop jacks are we talking about? My Omega doesn't leak and is a far better product in my opinion than the Bluepoint/Snap-on. I have both, as mentioned earlier.
approx 8+ different brans.
2 being omega.
1 of those omega leaking.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
