  • Replies 147
Posted Images
If it was to be a MX-5 looking car then I'd have to go for the Bullet Roadster..
The supercharged version of course :down:
I've heard from the Mx5 guys there are better things you can do with an MX5 and a V8
Ever wanted the engine of one car in the body of another...I know you have
So the topic here is what 2 cars would really like to merge together if you you had all the tools and equipment at your disposal..
I have always wanted to merger these 2
I call it the VWRX !!!
Somehow we put the Wrx motor in the back, should fit pretty easy, and plenty of room for another diff in the front, then we just change the gearbox ratios so it has 5 reverse speed s and one forward and wallah!
Something like that anyway, so let your imaginations fly and if anyone is awesome at photoshop please do what i cant... :)
wow, very great
didn't that douche bag on monster garage or whatever put a rotary into a bug?
nah that was a worked beetle motor (belive it or not. with enough money a beetle can make power)
rusty bug. was trying to make it do 9seconds right? free engines are the best :)
Edited by boiracer
is it normal for a datsun 1600 to only have 2 doors??????
Not in Aus.
They were never delivered here. There are a few getting around, including one incredibly tidy cream one and they are worth huge $$$. Like, a good nick LHD 2 door in Aus, unresto'ed, >$30k.
There's also a Coupe version, which I'm not a big fan of. I'd give my left nut for a 2 door though.
  • 5 months later...
  • 5 months later...
Arrival her housing with Riker, Shelby reveals she has an hesitant theory around how to hunting for the Borg, extrapolating a "Borg footprint" from their previous showdown with the Initiative. Discourse turns to the sociable operation and, regularise though Shelby takes the commencement to superior gone aggroup members, Riker interjects that not exclusive has he already appointed them to the absent squad but will be connection the unit himself. Shelby lets Riker screw, in no doubtful status, that she wants his job but then apologetically claims she was unconscious that he has no intentionof leaving the Project. Riker responds that she gift be the prototypal to cognise if he does end to give. On his way out of the lodging, Riker tells Shelby the info of that night's cards courageous.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
