In all it's glory - following for AC's 1:25 then my creative line through 1
bout bloody time you overtook that pesky R31 Paul :P
Great onboard footage and nice driving mate :thumbsup:
PS your Nismo tachometer is disconnected because your using other means to track your speed aside from the electronic tachometer displayed?
Yeah the speedo cable broke recently so in the process of getting another one. Hopefully cable isn't too hard to R&R, but I am guessing it will be...
im not sure on that one Paul but I can't imagine it being as much as a PITA to change compared to changing / replacing a clutch and gearbox
  • 3 weeks later...
Hehe nah all good Ant's, I only push the braking markers where I have run off, pretty much T1 only at Sandown. Always able to wash off enough speed.
Tyres were too hot after a couple of faster laps and just didn't want to turn in, so I decided to straighten up and was going quite slow once I actually left the track. Brakes are unpredictable too with the ABS unit in there, really inconsistent so once I sort that.
  • 3 months later...
Sandown yesterday, cracked into the 19's. Can certainly see more time in there too which is good - particularly around the sweeper (and fixing the ABS issues!).
Put some high density foam around the radiator which works a treat, big difference. Could keep going for the entire session with water temps not getting any higher than 90c and good oil temps. Going to get trackart / Andrew to make up some proper alloy ducting and it should be good all year round. So I am happy with the oil cooler sitting in the radiator end tank - seems like a good solution and easy / tidy from a packaging perspective.
  • Like 4
very nice Paul
Was the radiator moving around before the foam was installed causing the increase in water temps?
very nice Paul
Nah just air escaping around the sides and top and not passing through the radiator. More is now forced through the radiator. Can definitely improve further with some proper alloy ducting, would probably just want to knock another 5 or so degrees off max water temp, oil was happy around 100-110c. The ducting would bring both down a touch.
Paul, sub 1.20s is getting quick. Well done. Be interested so see the rad set up you're considering as track temps are always an issue...Maybe let me know when you're down at Trackart next as I've got to go there too?
Cheers.
Cheers.
Cheers. Got a touch more weight I can take out here and there. Compliance intrusion bars being an obvious one, could also do carbon / glass boot lid and wing. Don't need the passenger seat & mount either.
Hence why I reckon an 18 would be achievable with a few tweaks. Can see time in my driving as well, but you know... always good to leave a bit of fat make sure you bring it home in one piece!
There would be some easy time had in moving away from the stock diffs and modifying the transfer case but happy to get there on a standard drive line from the gearbox on for now.
For sure will let you know re: track art.
Paul
did u retain factory power steering? I am looking at a EPAS electric kit for my build.....any thoughts?
Do u find the steering really heavy when tracking the car and the front wheel drive is engaged. Almost to the point of being exhausting after five or six laps at pi?
Thinking the epas kit will strip a fair bit of weight and maybe give me a better overall steering package? What do you recon?
Cheers.
take her to PI paul. Cant wait to see your time there!!!!
Paul
Yeah steering is quite heavy - still factory, I think because of messing with the HICAS it no longer lightens up at lower speed. It also seems a bit variable - seems to get quite heavy for no obvious reason.
Just watched an EPAS vid would be a nice solution for sure. Could definitely cut down some weight there getting rid of the reservoir & pump etc.
And yeah itching to have a crack at PI with it, will be good fun!
Yes mine get heavy for no apparant reason. Some times it is like u have to wrestle the car at PI.
I am definately going to do something funky. At the very least an mr2 electric hydraulic pump plumbed into the system.
Maybe a full electric servo system like epas. This looks to require a whole new manual rack though.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
