hey guys, looking at getting my cars tuned, both have wolf systems in them
i was gonna go to status(chequerd) but they state on the website they dont tune wolfs.
do any of you know where i can get a good tune done?
i know alot of ppl dont like wolf but the cars came with them so may aswell use them.
cheers
Gezza
https://www.sau.com.au/forums/topic/329023-who-can-tune-a-wolf-ecu/
Rank Rotory in Moorabbin...tuned my old R33 gtst
They closed down years ago mate. I'm pretty sure they have something to do with Sabbadin now, I remember seeing Rank Rotary stickers on their door. This was a while back tho.
Thanks for the update...last time I used them was a while ago so its news to me. :D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
