Just got the car back yesterday from the workshop. Installed EastBear kit with rear diffuser, GTR bonnet and aerocatch pins and decided to mount the canards today so I took some quick shots.
Edited by john-e boi
Why not? I have a third one in the garage!!! :cheers:
Although the one on the left is almost sold..... :/
Why Jack?!
Take me for a spin before you sold it please.
